Author Topic: Kymco Agility 50 modified wiring for avoid problems  (Read 3100 times)
ConradFr
« on: October 01, 2014, 08:48:15 AM »
Hello
If you want to avoid breakdowns and problems caused by switches, you can change the wiring
I'll start posting for light switches and then I'll post for the other switches.
You can download all the files in a compressed zip here
Updated on september 24, 2021
https://drive.google.com/file/d/0B5Pa8JyT0MA_X3pYX2EyY3poVlE/view?usp=sharing&resourcekey=0-OWW5GAKAtiBFzKXE0fFI2Q
The zip file contain :
Original wiring
https://drive.google.com/file/d/0B5Pa8JyT0MA_QWVLOEl2NXhjVkE/edit?usp=sharing
Modified wiring
https://drive.google.com/file/d/0B5Pa8JyT0MA_VThOSUtNR2M3bW8/edit?usp=sharing
Animated version
https://drive.google.com/file/d/0B5Pa8JyT0MA_OE1FNGhXT2xuWTg/view?usp=sharing
And now the general 12V switch (Battery_On)
Original wiring
https://drive.google.com/file/d/0B5Pa8JyT0MA_U0JHOEJfd2s4bzA/edit?usp=sharing
Modified wiring
https://drive.google.com/file/d/0B5Pa8JyT0MA_YVVubmtyZ0RyQ0k/edit?usp=sharing
Animated version
https://drive.google.com/file/d/0B5Pa8JyT0MA_UVl5UUVWdmg4V00/edit?usp=sharing
And the last with the stop switches
Original wiring
https://drive.google.com/file/d/0B5Pa8JyT0MA_ekUzNWs3TFJYdTQ/edit?usp=sharing
Modified wiring
https://drive.google.com/file/d/0B5Pa8JyT0MA_aXQyUmtBdlZGeU0/edit?usp=sharing
Animated version
https://drive.google.com/file/d/0B5Pa8JyT0MA_OXIwWjZsU3d4Mk0/edit?usp=sharing
With theses mods the switches carry only the small current of the coil relays so we dont have problems  never with the switches
In few days i will post the pictures of the pcb wih the relays and the wirings
Nice day
« Last Edit: September 28, 2021, 02:20:53 PM by ConradFr »
baddi
Re: Kymco Agility 50 modified wiring for avoid problems
« Reply #1 on: November 07, 2014, 04:17:09 PM »
Thanks for the contribution, even though i have never had any trouble with this. :)
I was thinking about letting the battery supply the lighting instead so LED lights can be added, but i don't know what to search for to find the connectors to the wire harness. :)
Have you got a good place to buy them? :D
« Reply #2 on: November 07, 2014, 04:28:52 PM »
The main problem I've seen with the switches aren't due to voltage but from corrosion building up on the contacts. But this is still a great write up and useful wiring diagrams. All the bigger bikes have high and low beam relays for the lights.
« Reply #3 on: November 08, 2014, 02:36:28 AM »
Also for good lighting you can hook up the lights comeing right from the stator.did my gy6 swap like that worked great.
