Did you miss your
activation email
5 micron fuel filter
Topic: 5 micron fuel filter (Read 732 times)
Yager200i
Sr. Member
October 01, 2014, 03:25:00 PM »
I recently got some bad gas that partially plugged my fuel injector and gunked up the entire intake:
http://www.kymcoforum.com/index.php?topic=3672.msg126430#msg126430
I've got a 12 micron fuel filter installed (Wix 33031 / Napa 3031), but apparently the crud was smaller than that.
I had to tear apart the entire intake system, the fuel hose and fuel injector, etc. and clean it out.
So, I'm looking for a 5 micron or smaller inline fuel filter that is small enough to fit in a scooter. I found one spin-on canister type that's 5 micron, but it's too large to fit under the Tupperware, so that's out.
Anyone know of one?
Carter Merz
Re: 5 micron fuel filter
October 01, 2014, 03:35:35 PM »
Do you use dirty corn gas? Sounds like an ethanol concentration.
Yager200i
Sr. Member
October 01, 2014, 04:17:36 PM »
I use Costco gas. It's got 10% ethanol. Never had the problem before, but I pulled in when the truck was filling the storage tank, and apparently that sucked up all the trash off the bottom of the tank, and their filters didn't catch it.
Carter Merz
Reply #3 on:
October 01, 2014, 04:22:10 PM »
I HATE e10 with a passion. I'm lucky enough to live next to the river and lakes so there are plenty of stations selling "clear" gas. World of difference
Back
