Author Topic: HELPPPPPP Scooter Wont start  (Read 1421 times)
Hawkins654
« on: October 11, 2014, 10:26:44 AM »
My scooter is a 07plate LC, was riding fine for a few months then all of cut out when waiting at the lights,
when trying to restart the ped it wouldn't start.
being a rookie with scooters it has completely fried me as to what's wrong.
I have read a lot of posts and spoke to a few people to try and diagnose the problem.
-Have looked inside and I am getting fuel to the spark plug, changed it and tested against the frame for a spark.
-Changed the battery as was dead from trying to start,
-The starter relay was corroded on the contact points so changed,
-Tried to kick start and doesn't seem like anything is there,
When I try to start the ped it does try to start on the electric but just sounds like its just using the battery and the engine is not kicking in.
Can someone please help me im giving up with it now hahaha
maddog21
Re: HELPPPPPP Scooter Wont start
« Reply #1 on: October 11, 2014, 01:25:34 PM »
Is it turning real free like there is no compresion if its turning over fast ut needs rebuilt
Hawkins654
« Reply #2 on: October 11, 2014, 01:32:35 PM »
the kick start?       No when I kick it feels like it should do, just doesn't start,,,
maddog21
« Reply #3 on: October 11, 2014, 01:41:03 PM »
Its getting spar?
maddog21
« Reply #4 on: October 11, 2014, 01:46:15 PM »
If its getting spark and gas and has compression it will start so make sure that its getting enough spark and see if spark plug is wet after trying to start if it is wet and has spark then it probably doesnt have enough compression do you or can you get a compression gage to check it
Hawkins654
« Reply #5 on: October 11, 2014, 02:27:21 PM »
i havent got the kit to do a compression test, but i have just watched a video on youtube of a scooter with low compression and its doing exactly the same as mine.
Will get this checked by a friend who has the gauge etc.
if this is the reason for the scoot to not start what would need replacing? piston rings?
thanks for the help
« Last Edit: October 11, 2014, 02:58:54 PM by Hawkins654 »
maddog21
« Reply #6 on: October 11, 2014, 03:17:05 PM »
Yes piston and rings and have to take jug off snd see how bad it is if its to bad you will to get bigger piston and rings and take jug to a machine shop if its not bad you will need to hone it
Hawkins654
« Reply #7 on: October 11, 2014, 03:41:35 PM »
ok thanks for all your help very grateful.
Rage
« Reply #8 on: October 21, 2014, 09:47:06 AM »
Have u tried starter fluid? My 02 lc did the same thing. Turns out I blew a head gasket. Was starting to burn water/coolant.
