Author Topic: Speed Restrictor  (Read 6455 times)
kaktuschick
Speed Restrictor
« on: October 13, 2014, 05:28:10 PM »
Is there a way to remove some sort of restrictor from the People s200 to make it go just a LITTLE faster? I'd love it if I could get my scooter up to about 70mph. I don't know much about this sort of thing. Would it be possible? Would it damage anything?
I was doing a google search, asking about why the scooter tends to jerk a bit when I go too fast or down hill and I came across a post in another  forum about a 'rev restrictor' and that got me to thinking-maybe there is some sort of governor or restrictor that could be removed to add a little more speed to my scooter. I'd love to be able to go just a tad faster so that when I am forced to get on the interstate, I'd be less likely to be mowed down.
ANY replies would be appreciated. And, if this questions is a stupid one, I apologize for the annoyance, lol.
Re: Speed Restrictor
« Reply #1 on: October 13, 2014, 06:21:16 PM »
There is no restriction on the s200. Your restricted by power, that's it. I have extensively tuned my girlfriends s200 and she hits 80 on the speed o no problem. The s200 has a tps based cdi so you don't h want to swap it, there is no "rev limit". If you want more top speed, the BEST thing you can do on the s200 is order yourself a Dr. Pulley variator I've seen them as low as $80 on eBay new. Also get 12g Dr pulley sliders. This will get you to about 70. Another great upgrade for that bike is a larger carb, both my gf and my cousin i have upgraded their carb to a 30mm cvk off of 250cc Kymco. This is the main upgrade in top speed but fairly expensive. A cam will help you too, but that is a pretty involved installation of you haven't done it before. The s200 had amazing potential and with a grand or so i could get it going 100mph pretty easy. All the parts I've listed will be four the gy6 engine, because the s200 shares almost all engine and trans parts with gy6, so if you order the variator make sure it says will work with gy6 150cc. Good luck, pm me if you need more tips! (Ps i have a 250 carb for sale too 😉)
kaktuschick
« Reply #2 on: November 03, 2014, 07:18:43 PM »
THank you VERY MUCH for that info! I'm really excited about learning about how my scooter runs and learning to fix problems on my own! ALL of the info and help I can get is greatly appreciated. :)
08087
  • 09' Peoples 200, NJ
« Reply #3 on: November 21, 2014, 08:19:24 PM »
I don't plan on making any changes to my 200s but it's good to hear that there are simple things that can be done. My question is, how much will that change MPG and normal for the scooter speeds (40 MPH or so/ and city riding)?
Assuming my 200s is normal when I'm hitting it's normal limits 55+ MPH the engine sounds like it's ready to shake itself apart, do these changes cause any premature failure?
« Reply #4 on: November 21, 2014, 08:53:46 PM »
Most of the things I mentioned actually increase reliability. The easier your motor works going 55-60 the longer it will last.
08087
« Reply #5 on: November 21, 2014, 11:14:02 PM »
Thanks, I assume this will also give a slower take off, not that that matters much to me, but you have a good point, I was thinking it would increase RPM for greater speed not slow the Rev's the engine puts out.
« Reply #6 on: November 21, 2014, 11:45:44 PM »
It depends on what you do exactly, if you build your bike for high torque at a decent RPM then it should last better than stock, if you build it to scream at any speed then it won't. Things like adding a Dr. Pulley CVT, open exhaust, and large carb and camshaft will not decrease reliability.
08087
« Reply #7 on: November 22, 2014, 01:34:20 AM »
If I went to a dealer shop and asked them to do those changes minus the cams what do you think they'd charge?
« Reply #8 on: November 22, 2014, 03:29:39 AM »
For you?
08087
« Reply #9 on: November 24, 2014, 07:21:22 PM »
For you?
Zombie, I'll look at the clip later today, I ask about having it done as my hands don't cooperate with my mind and time is limited for me having a young daughter, she always wants to help but doesn't have the ability to sit still yet if you know what I mean.
Thanks for the clips. 08
« Reply #10 on: November 24, 2014, 07:30:15 PM »
It was just my estimate of what your dealer would charge... One million dollars!
I have modified my browser, and it no longer embeds the Ytube vids. If you were able to see the embedded pict you would have gotten it right away...
08087
« Reply #11 on: November 24, 2014, 11:03:26 PM »
I can see or view from this CPU, wil look in a while from another source, thanks.
08087
« Reply #12 on: November 25, 2014, 12:41:21 AM »
[/quote
Ok mini me, I got you.
« Reply #13 on: November 25, 2014, 02:42:28 AM »
LOL!!!! :-*
0BARK4322
« Reply #14 on: May 07, 2015, 08:41:38 AM »
Still looking at around $500 ???
ALL STOCK
