Author Topic: Checking oil  (Read 1096 times)
mverps
Checking oil
« on: October 15, 2014, 06:09:55 PM »
I keep reading differing opinions on this. Do you check the oil with the dipstick unscrewed, or do you screw it back in and then out to check it?
thanks, Mike
Re: Checking oil
« Reply #1 on: October 15, 2014, 06:16:00 PM »
you check the oil unscrewed!!!! it says so in your manual
Re: Checking oil
« Reply #2 on: October 15, 2014, 06:18:39 PM »
unscrewed.
 The action of jiggling it around, lining up the threads, twisting it in/out can give a false reading.
You get a kind of cotton candy effect.
mverps
Re: Checking oil
« Reply #3 on: October 15, 2014, 06:19:31 PM »
thanks, I read in one manual to check it unscrewed, and in another manual to check it screwed in. So you can see my confusion. I appreciate your input.
Re: Checking oil
« Reply #4 on: October 15, 2014, 06:32:33 PM »
Also, obvious, but make sure it is on the center stand on level ground!!!! You have no idea how many customers I've had over-fill their oil because they had it on the kickstand!!
