Author Topic: rear tire replacement  (Read 6663 times)
aaron8
Re: rear tire replacement
« Reply #15 on: October 21, 2014, 05:02:26 PM »
PM SENT.
boo
« Reply #16 on: October 22, 2014, 09:56:38 PM »
On my scoot, if i reuse the gasket it leaks slightly. Best way to test it, install everything and start the bike, the kill it by plugging the exhaust by your finger. It'll either hold pressure and go WOOOSH when you let go, or if its leaking you will hear a slight hisss instead of it holding pressure.
Thanks.
300GTI black
Pro 2A - member GOA & NRA
Texxan
« Reply #17 on: May 05, 2019, 12:47:36 AM »
I know this is old but....what gasket????
« Reply #18 on: May 05, 2019, 01:19:43 PM »
Exhaust pipe to head. It's a circular flex type that fitsinto a recess in both the head and pipe flange. Someone one here pointed out you can just slip the muffler off and not have to fool with the exhaust pipe.
Texxan
« Reply #19 on: May 16, 2019, 02:50:59 AM »
Thats why I asked...why would you take whole pipe off?
This rear tire replacement is a pain in the ass...two different pullers,new bearing for rear fork,two seals....
Funny thing is dealer had gasket in stock for final drive. (bearings failing in final drive)
« Reply #20 on: May 16, 2019, 12:49:37 PM »
Gasket for the gearbox in stock? Musta been a big mistake!
