Author Topic: Like 50 with White Walls  (Read 2262 times)
aaron8
« on: October 20, 2014, 11:14:35 PM »
Put these on for a customer. I think they look great!
Re: Like 50 with White Walls
« Reply #1 on: October 20, 2014, 11:31:58 PM »
I love them. What brand did you install? I think Chen Shin were the only brand I could find in wide whites.
They are the next tire going on my "Vruk" 4t frame bike.
aaron8
« Reply #2 on: October 21, 2014, 12:01:53 AM »
Naidun brand
got them from Parts for scooters
« Reply #3 on: October 21, 2014, 02:07:47 AM »
Nylon Bias ply I assume... What was your impression of them while mounting?
I recently bought a pair of some off brand nylon tires that were soooo slippery I could barely handle them. They did no better on the road either.
Just in your opinion... do you think they will last long enough to give them a try? maybe 3-4k miles?
aaron8
« Reply #4 on: October 21, 2014, 02:45:22 AM »
they seem to be a decent tire. but the Likes do come with better tires than the agility's
4 ply rating
they mounted easy and took air with out using a ratchet strap.
they get fairly dirty when mounting so you'll have to spend 10 mins just cleaning them back up.
i would say they should last longer than 4k miles on a 50cc
« Reply #5 on: October 21, 2014, 03:47:33 AM »
I appreciate your input. I've been eyeballing a set for quite awhile.
After the last "cheepos" I bought, I really have nothing to lose. I'm starting to think like a "trophy collector". As long as they look good, who cares if they cook.
herrspoot
« Reply #6 on: December 26, 2014, 08:46:27 PM »
Looks nice! Are the tires hand mount-able with some levers? Haven't been around scooters long enough to change them yet :)
2012 Like 50 2t
  Derestricted bushing
  Derestricted stock exhaust
  Derestricted stock airbox
  100 MJ
  Biondi windshield (with custom mounts)
"The pen is mightier than the sword, and is considerably easier to write with." Marty Feldman
« Reply #7 on: December 26, 2014, 11:21:25 PM »
A set of 12" or longer levers will do any scooter tire. The trick is in keeping the beads in the center of the rim so you have more clearance in getting the opposite bead over the rim.
ParaIndiana
« Reply #8 on: December 30, 2014, 10:51:22 PM »
I've thought about getting these tires too, but the amount of dirt and junk that the white would pick up would have my OCD going and I really don't want to have to clean my tires every day. I already use spray wax several times a week to keep things shiny. 2 strokes are usually just a bit grungier than other scooters too.
2011 Kymco Like 50 2t
Malossi 70 BBK
Malossi 19MM Carb
Stage 6 Sport Pro Clutch
Pod air filter
Malossi CF Reeds
Polini torque spring: Blue
Naraku Sport Variator
Naraku Sport Torque Driver
Naraku Half Pulley
5.5G Dr. Pully Sliders
Stage 6 +15% Primary Gear Kit
Malossi Belt
Pre-mix Fuel  45:1
« Reply #9 on: December 31, 2014, 02:34:19 AM »
I gave up on cleaning scooters. About once a year I'll hit them w/ Bleach, and forget them again.
