Author Topic: found these on ebay. thoughts?  (Read 11814 times)
donjack
Re: found these on ebay. thoughts?
« Reply #60 on: January 20, 2015, 11:05:28 AM »
Hello mamo, yes they they are very good!!
To answer your questions,
1. The cage was causing scratching to the mudguard.
2. You can change the light mode by the toggle switch, switch on=very bright, switch on off on = bright, switch on off on off on for strobe mode.
3. Yes the + connects to the battery directly.
Hope this helps.
Cheers
Don.
mamo
    • みんから/まもchan/Downtown 300i
« Reply #61 on: January 21, 2015, 04:40:51 AM »
Hello,donjack  ;D
Always thank you.
mamo
« Reply #62 on: January 21, 2015, 09:53:38 AM »
Hello,donjack   ;D
I'm sorry many times.
When I attach it outward than now, does it come in contact with a fender?
donjack
« Reply #63 on: January 22, 2015, 08:06:53 PM »
hello mamo, when the dt was on centre stand it was ok, once off stand and travelling that's when the scratches appeared, everything is ok now with the lower part of the cage removed.
Cheers,
Don.
mamo
« Reply #64 on: January 28, 2015, 03:28:42 AM »
Hello,donjack
I was attached at last.
But a terrible explosion became the next problem. :-[
What kind of method do you coordinate a sound by?
« Last Edit: January 28, 2015, 04:57:29 AM by mamo »
