Author Topic: Replace engine 50 to 125cc?  (Read 1117 times)
zero
« on: October 30, 2014, 09:56:06 AM »
Hi, friend I want to replace engine on my people s50 4t with 125cc or150cc , this is possible?
Re: Replace engine 50 to 125cc?
« Reply #1 on: October 30, 2014, 03:49:12 PM »
Possible, yes, easy, no.
zero
« Reply #2 on: October 31, 2014, 07:50:36 AM »
Thanks friend, suspension of the engine is different???
« Reply #3 on: October 31, 2014, 03:32:07 PM »
Suspension isn't the problem, you would have to custom make a wiring harness, custom make the motor mount. It'd be cool, but you can give a decent s200 for under $1500 that already is what your talking about.
zero
« Reply #4 on: November 01, 2014, 06:53:17 PM »
Understand :), thanks :)
