Did you miss your
activation email
Scooters - 125 to 300
Grandvista 250
Handlebar Size
Topic: Handlebar Size (Read 1204 times)
jayocampo88
Newbie
Handlebar Size
October 31, 2014, 04:23:52 AM »
I have been wanting to add some aftermarket bar end mirrors on the Scoot...
I was wondering what size are they? Are they the typical 7/8" hole or are they a different size?? I have try measuring but I just want to double check.
Thank you
Carter Merz
Re: Handlebar Size
October 31, 2014, 04:47:56 AM »
It actually may be hard to add bar end mirrors without modifying them because the grand Vista has threaded ends.
jayocampo88
Newbie
Re: Handlebar Size
October 31, 2014, 05:04:20 AM »
DANG!!! If I may bother you once more...
What size are the bolts? Could I just bolt on a mirror to them in that case?
Carter Merz
Re: Handlebar Size
Reply #3 on:
October 31, 2014, 06:57:12 AM »
I have bolted mirrors to them in the past, doubt remember the size just pull off the bar end and take the bolt to a hardware store. You should be able to make most bar end mirrors work.
Back
