Author Topic: Luggage Box Light  (Read 1709 times)
RubenC
Luggage Box Light
« on: October 31, 2014, 08:07:06 PM »
Hi,
My luggage box LED light is out.  Does anyone know what type of replacement LED bulb to replace it with?
I know. I know. One that works.
Thank you for your help
From the Great Nation called Texas. Oops I mean the Great State called Texas
windwheeler
    • WindStrom windshields
Re: Luggage Box Light
« Reply #1 on: October 31, 2014, 09:57:48 PM »
Just had it open a few days ago but didn't look.
One thing I found out, if you turn/install the bulb 180 degree turned around in the socket (then "wrong"), it will not work.  Not like the old bulbs where it did not matter.
« Last Edit: November 01, 2014, 03:39:19 AM by windwheeler »
donjack
« Reply #3 on: November 01, 2014, 02:16:55 AM »
You should check out superbrightleds.com and look at their glove box lights. Wayyyyy brighter than the stock met in light and you can wire it to the original switch.
sklnzl
« Reply #4 on: November 04, 2014, 03:42:30 PM »
In my opinion ,the luggage box light has no utility at all ,it is too low in the box.
nushipwright
« Reply #5 on: November 06, 2014, 01:47:59 PM »
I don't even know where the light should be. never seen it being lit since the first day I bought the bike (used)...
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.”  - Mark Twain
. mostly 2up city
« Reply #6 on: December 07, 2014, 02:23:22 AM »
  the bulb is burnt or it is not pluged in under the met in box, the light is so low it is always covered with some thing,.  I was thinking to put a strip of led lights around the top at the back, off of the same power supply,.
