Author Topic: starting wires  (Read 3736 times)
sportsman014
starting wires
« on: October 20, 2009, 01:20:38 AM »
Some one tore the wires out of the ignition solenoid.  what is the color codes for where each wire goes?
thank you
Shaka
Re: starting wires
« Reply #1 on: October 20, 2009, 01:48:51 AM »
Those bastards!  >:(  Here is a pic from the manual, hope it helps!
sportsman014
Re: starting wires
« Reply #2 on: October 20, 2009, 03:01:48 AM »
that peice is luckly still intact what i am looking for is which wires solder to which spot on the actual ignition area
thanks in advance
Shaka
Re: starting wires
« Reply #3 on: October 20, 2009, 03:09:01 AM »
Got ya, that one is a little trickier!  You should be able to take a voltmeter and check continuity between the points while turning the key to the different positions.  Here is a diagram of what should be connected.
sportsman014
Re: starting wires
« Reply #4 on: October 20, 2009, 03:22:56 AM »
ok i dont have a volt meter either... do u know what color wire goes where starting at the top and rotating clockwise..
Re: starting wires
« Reply #5 on: October 20, 2009, 03:53:12 AM »
Get em shaka!
Shaka
Re: starting wires
« Reply #6 on: October 20, 2009, 04:39:40 AM »
Well, I think i stuck out on solving this one. :P  I don't an agility to look at.  I do have an ignition off another scoot, but the wires are different.  I think you might be best off investing in a volt meter, it's cheaper than a new ignition!  ;)  Otherwise, maybe someone else can look at theirs and send you a pic.
Re: starting wires
« Reply #7 on: October 20, 2009, 10:52:39 AM »
...gimme a few minutes...i'll go look at mine...
sportsman014
Re: starting wires
« Reply #8 on: October 20, 2009, 01:06:07 PM »
thank you
Re: starting wires
« Reply #9 on: October 20, 2009, 01:57:48 PM »
thank you
..are you wanting the ignition switch connector?
..where you insert the key?
sportsman014
Re: starting wires
« Reply #10 on: October 20, 2009, 02:05:01 PM »
the back of the key silinoid has 5 wires that attach to it  i was wonder what wire goes where
Re: starting wires
« Reply #11 on: October 20, 2009, 02:42:02 PM »
...ok..i'll get that info for you, but it's gonna be this afternoon before I can get to it...
peace
sportsman014
Re: starting wires
« Reply #12 on: October 20, 2009, 03:35:54 PM »
got ahold of the shop were i bought the bike and the order is  starting at 12 o'clock is  Black/white,  Black, Green, green, red.
THe green wire at 5o'clock is the one that is right next to the black wire in the terminal..
hopefully this might help someone else down the road.
thanks everyone for the help!!
Shaka
Re: starting wires
« Reply #13 on: October 20, 2009, 04:26:51 PM »
I'm glad you got it figured out!
Re: starting wires
« Reply #14 on: October 20, 2009, 04:54:51 PM »
..damn lotta good this frickin' electrical schematic I have is...doesn't even show a black/white wire ANYWHERE on the print...
