Author Topic: oil light comes on when revving  (Read 727 times)
Triesandluth
« on: November 10, 2014, 08:23:42 PM »
Just cleaned the jets on my carb, reconnected my electric choke and reassembled everything.  Now my oil light comes on when i rev the engine.  What did i do!?! Ihave also recently added a little more oil.  Help!!
Re: oil light comes on when revving
« Reply #1 on: November 10, 2014, 08:47:03 PM »
Is your battery dead? Do you have to kick start it? If the battery is dead it'll trip the oil light circuit out.
Triesandluth
« Reply #2 on: November 10, 2014, 09:36:18 PM »
Iacted hastily.  I had also taken off the front plastic today,  disconnected and reconnected the head light.  The connection had some corrosion that i disturbed. I took it back apart and cleaned it,  reconnected,  now everything is fine.  Not only the oil light was lighting up but the turn signals would too.  I'm not very familiar with the electrical side. I find that odd.
0BARK4322
« Reply #3 on: December 06, 2014, 07:20:54 PM »
the oil light comes on for a little while when cold but always turns off after a few seconds
ALL STOCK
