Author Topic: Need help guys !!! Crank problem very SERIOUS!!! Pls  (Read 789 times)
Mroz
« on: November 12, 2014, 03:25:12 AM »
Ok , take appart trans.
, variator out , crank seal broken ,no oil leak !
Shaft has a BIG PLAY in it , i can move it up a down righ and left a lot about a half centimeter , scooter dyeing often , recently change piston and cylinder cause no oil lol...
Crank bearing bad ? How can i check that ?
Pls help ..
Re: Need help guys !!! Crank problem very SERIOUS!!! Pls
« Reply #1 on: November 12, 2014, 02:10:57 PM »
Replace engine with one that has not been worked on by an incompetent.
Mroz
« Reply #2 on: November 12, 2014, 03:09:02 PM »
That would be too easy ....
I would rather find those bad parts and start there ....
tortoise
« Reply #3 on: November 12, 2014, 03:25:52 PM »
Pls help
Context?  Segmenting the discussion by posting multiple threads on the same topic complicates finding a solution.
« Reply #4 on: November 12, 2014, 04:43:49 PM »
It kinda sounds like you answered your own question. You have play, your crank is bad lol. It's quite the undertaking to replace.
