Did you miss your
activation email
Scooters - 125 to 300
Super 8 150
10w40 VS. 10w30
Topic: 10w40 VS. 10w30 (Read 1351 times)
Amaro321
Full Member
10w40 VS. 10w30
November 12, 2014, 04:02:22 PM »
Soooo I was at my local bike shop to pick up some oil and decided to go with a Honda Pro Synthetic oil but didn't realize till after I had drained my oil that it was 10w30 instead of the factory recommended 10w40.
On my way to work this morning, I couldn't help but notice how "peppy" my S8 felt this morning, easily getting up to 55-58 mph NOT WOT more like 3/4 or 6/8ths of throttle.
SO My question is. Is this safe?
2011 300i downtown 82,265 KM.
Re: 10w40 VS. 10w30
November 12, 2014, 09:27:59 PM »
the differance in oil is for the temp. where you live,.warm temp. you are good ,. cold temp. time for a change to the right oil,. freezing here, so I use 5 W 50, good for all temp.
Carter Merz
Re: 10w40 VS. 10w30
November 12, 2014, 10:58:56 PM »
10w30 will be better for cold temp 10w40 will be better for warm temp. I would not use 10w30 in the summer, might thin out too much and not provide proper lubrication. As long as you have the right amount of oil in the scoot, and are not trying to go 80mph downhill, then engine won't be damaged.
Amaro321
Full Member
10w40 VS. 10w30
Reply #3 on:
November 13, 2014, 05:00:22 AM »
Lol thank you brother. Looks like I'm good then. Now tomorrow I'll change the gear oil and pray it doesn't keep leaking out the air box 😳
Back
