Author Topic: tach doesn't work  (Read 1090 times)
chaz35
  • old guy
tach doesn't work
« on: November 13, 2014, 05:30:25 PM »
My tach needle is pegged to the right.  I took the plastic cover off and moved it back to zero.  It actually worked for a little while, but it's back to being maxed out again.  Is there something to check for that might be causing this or do I just need to replace it?  Thanks for any replies.  Cheers
chaz35
  • old guy
Re: tach doesn't work
« Reply #1 on: April 10, 2016, 03:45:19 PM »
update:  I bought new speedo assembly and unfortunately got in the wrong one (see for sale thread if interested in buying).  The problem was the speedometer cable connection, 2003 has an angled connection, I received the later version that has a straight connection.  I did connect all the wiring to test, and new tach worked properly all wired up.  So, at least I know I need a new tach that fits, it's not a wiring problem between the tach and engine.  Cheers
paceneedsstides
« Reply #2 on: April 13, 2016, 10:28:34 PM »
Like 50 doesn't have tach so can't help you there I installed a digital aftermarket one.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
Triesandluth
« Reply #3 on: April 21, 2016, 07:20:09 PM »
Good to know!
