Got jets and installed 38 slow, 90 main. Was hard to start, because it flooded engine. Took me awhile to realize engine was flooded, but once I did, I got it started (start with throttle open).
Not there yet, but definitely runs better. I am going to run it a little more and separate the CDI green wire before I change the jets again. Then, will probably go back to 35 slow and try 95 main.
I was able to determine I had 35 slow 82 main jets in original carb. I got as used scooter, so maybe changed from factory, but that's the way I got it.
Also, I bought after market jets, which are OK, but pretty hard to read marking. Next order, I will probably pay a little more and get OEM Keihin jets. Ciao
