Author Topic: air filter assembly Function  (Read 1738 times)
William Colon
« on: November 21, 2014, 12:26:17 AM »
That function has lines that enter the air filter ? it may cause to remove the air filter?; I was broken  the base where the air filter goes. Thanks
Re: air filter assembly Function
« Reply #1 on: November 21, 2014, 12:59:35 AM »
Your going to have to re-design your sentence to make sense.
« Reply #2 on: November 21, 2014, 02:04:48 AM »
 ;D ;D ;D, This might be our old friend Alex, or maybe some relation.
Have any of you seen the A.I. posts on various forums?
« Last Edit: November 21, 2014, 02:06:41 AM by zombie »
« Reply #3 on: November 21, 2014, 02:10:01 AM »
To answer the question... The pleated/accordion line or inlet tube has broken off the air box. It is NOT needed for the bike to run properly. It mainly keeps water out of the box when riding in the rain by being concealed inside the body panels.
Even a blind squirrel finds a nut from time to time.
