Author Topic: LED all out!  (Read 7244 times)
agilebda
LED all out!
« on: November 28, 2014, 02:12:15 AM »
Finally got my GTI entirely LED! Swapped out the headlight months ago and now the rear license plate light bulb is now LED.  Sweet huh?
Re: LED all out!
« Reply #1 on: November 28, 2014, 02:42:26 AM »
Is the headlight as good or better than the halogen? I've been thinking about doing h4 leds on my zuma
mrmike
  • Syuracuse, NY
Re: LED all out!
« Reply #2 on: November 28, 2014, 02:59:46 AM »
  Agiledba
   I really like the look of the whiter headlamp. I installed white led's in the European turn signal sockets, and would love the headlamp to match in whiteness. What brand and type of bulb did you use, and did it plug right in?
agilebda
Re: LED all out!
« Reply #3 on: November 29, 2014, 04:52:07 PM »
Hi guys, yes the LED in my opinion are better than the standard bulbs. Softer to the eye (oncoming traffic) and looks awesome. Matches the LED parking lights and gives the bike a whole new look. High beam is awesome too. Below is the amazon link where I purchased.
http://www.amazon.com/20-SMD-Light-Replacement-Bulbs-STICKER/dp/B006R34PB4/ref=sr_1_28?ie=UTF8&qid=1417278868&sr=8-28&keywords=12+volt+led+bulbs
http://www.amazon.com/720LM-Xenon-White-6000K-Headlight/dp/B00PRW2KJK/ref=sr_1_44?ie=UTF8&qid=1417279689&sr=8-44&keywords=12+volt+led+h4+headlight
Direct replacement to the OEM bulb. Easy to install
« Last Edit: November 29, 2014, 04:55:02 PM by agilebda »
mrmike
  • Syuracuse, NY
Re: LED all out!
« Reply #4 on: December 02, 2014, 11:32:13 PM »
Thank you for that info. I'll order my bulbs now and install them in April when I put the scoot on the road again.
DMblues01
  • 2012 Kymco Super 8 150
Re: LED all out!
« Reply #5 on: December 10, 2014, 03:43:38 PM »
Thank you for posting the link for these. I've been wanting to replace the H4 bulbs on my Super 8 150 with LEDs for a while. They look good and bright in the pic of your scoot. Do they give a good even light ahead of you at night? I've read mixed reviews of the other LED H4 bulbs I've looked into.
Duke- 8)
Roxana, IL
Yoda is my spiritual leader.
agilebda
Re: LED all out!
« Reply #6 on: December 19, 2014, 04:36:38 AM »
Was Never much of a fan of the Charging/lighter jack under the seat. So I decided to swap it out with a LED courtesy. What do you all think?
agilebda
Re: LED all out!
« Reply #7 on: December 19, 2014, 04:39:29 AM »
Duke- 8)
Yes DMblues,
They give awesome and even spread ahead of you. Very much like the OEM bulb. You wouldn't be disappointed. High beams are awesome on these H4 LED.
NeoGenesisMax
Re: LED all out!
« Reply #8 on: December 19, 2014, 05:29:19 PM »
Ok heres a question my google search didnt answer. What is an h4? How does that differ from led, hid, halogen, and normal bulbs
agilebda
Re: LED all out!
« Reply #9 on: December 19, 2014, 06:16:08 PM »
H4 is the bayonet  (housing type) I believe. I think it may stand for Headlight number 4. I stand corrected though. H4 bulbs can come in LED, Halogen, etc.......
agilebda
Re: LED all out!
« Reply #10 on: December 19, 2014, 08:22:27 PM »
NeoGenesisMax, here you go buddy:
mrmike
  • Syuracuse, NY
Re: LED all out!
« Reply #11 on: January 10, 2015, 03:46:47 PM »
 HELP!  I also like the bright white look of the LEDS on the front of my GT. I put cool white LEDS in the European turn signal lenses to further enhance the look. I saw this post and ordered the new headlight. Now for the problem. I took off the windshield, mirrors, and all the attaching screws. I don't know how to  open up the plastic tabs that snap the cover on. I don't want to break off or crack the cover. What's the secret??
agilebda
Re: LED all out!
« Reply #12 on: January 10, 2015, 04:03:33 PM »
Mr Mike. I would love to help you out. Which plastic screws are you referring to? Can you show me a pic?
If it's the black bullet looking clips they are fairly east to remove. Just take a screwdriver and push top center and they will release.
« Last Edit: January 10, 2015, 04:34:30 PM by agilebda »
mrmike
  • Syuracuse, NY
Re: LED all out!
« Reply #13 on: January 10, 2015, 08:16:45 PM »
Agiledba
  As I said. I took the windshield and mirrors off. I also removed 4 screws and two bolts that hold the handlebar cover together. I thought I could pull the cover apart and replace the headlight. There are several tabs along the seam of the two handlebar cover halves (Item 93205 + 93206 in the diagram) that I believe are holding it together. How do you unsnap these, or is there another way to access the headlight??
        Mr. Mike
doxbike
Re: LED all out!
« Reply #14 on: January 15, 2015, 03:20:17 AM »
Take pix Mrmike and do a tutorial so we can all take advantage.  I need to do the same to install the Stebl horn I just got.
