hi zombie i'm sorry but i didn't understand well your previous message, i've already bough a new cdi, today i tryed it, it goes a bit better, but it goes at 50 kmh (2 on the bike) after maybe 20 minutes with engine on, i think is too much also in winter, or not? here in venice we have 10° celsius, not so cool...
Anyway, i tryed to disassembly (is right disassembly? or dismount?
) the variator, I'm posting some pictures of that, maybe i got wrong when i change rollers and belt
First problem: after disassembly the carter this piece has fallen, do you know what is? I didn't see from where it fell
https://www.dropbox.com/s/uucspsuds9crgjn/20141203_121926.jpg?dl=0Next step, i see this all mounted
https://www.dropbox.com/s/z4by6bf7axfhwrd/20141203_121918.jpg?dl=0this the situation after removing first part of variator
https://www.dropbox.com/s/02vvctsj4an01c9/20141203_122058.jpg?dl=0it it right the belt over the drive boss? and is mounted on the correct side? with "teeth" against the drive boss?
This the variator open, are the rollers mounted well?
https://www.dropbox.com/s/sp7dmrywtve1ml6/20141203_122224.jpg?dl=0https://www.dropbox.com/s/h670ag7sv8nxlys/20141203_122234.jpg?dl=0this is the belt with the serial number, is correct for my scooter?
https://www.dropbox.com/s/hpkfzbdp1be9pp5/20141203_122131.jpg?dl=0finally, the rollers are 13x16x6.5g, if i go alone the accelleration is obviously better but really not so much, it was better before changing rollers, but i ask the seller the original rollers, i don't understand why i have this big difference, I hope that I did something wrong
Thank you again zombie!!
