Author Topic: replacement carb filter with choke and jetting for a bigger cylinder is 70cc max  (Read 1660 times)
KYMCO2TCHLTNC
Hi Can someone recommend some parts a bigger cylinder and piston a carb with choke and replacement after market filters and the carb jetting that might be needed if any. Is there a replacement filter with a built in choke? Does the sparkplug or variator make a difference? Where do I go to find some good parts I think I need a air breather I can choke.
Thanks +
Any one know the size of the glass fuse? I need to upgrade to one that resets itself.
Welcome to the forum Chlinic,
Start at SPI. http://www.spi-parts.com/ Call them up to set up a dealer account. Call yourself 2t Chlinic (business name), and let them know you will be paying sales tax at the time of purchase. That will save you approx. 40% on parts.
Get the Polini Corsa jug, and Jasil Top Racing variator from them.
Next do the same thing w/ Racing Planet... http://www.racingplanetusa.com/
Get an OKO 24mm flat slide carb/open filter kit, And a Malossi RED control spring for the clutch. I highly recommend a Stage 6 MK II clutch, and use their RED fly springs
Then hit Ebay for an Intake kit...   http://www.ebay.com/itm/Honda-DIO-Racing-Intake-Power-intake-kit-4-valves-/231104867975?pt=Motors_ATV_Parts_Accessories&hash=item35ceec6e87&vxp=mtr
Last call Cynthia at Scooter Alley in Hawaii. Get a Scorpion exhaust for a 70cc kit. All done!
solumized
Hey Zombie (And Chlinc sorry for stealing your post!)
Just a quick question based on your last post.  With all you have listed what would you estimate the cost of that being? ~$400?  Also, say I were to follow your advice, what kind of performance increase would I be expecting from this?  Just trying to figure out if doing something like this would be worth my while vs. just living with how the scooter currently performs!  Thanks a head of time!
One thing you guys should remember, you will NOT be able to daily drive your bike without tuning it every day and fussing with it. You should get 55-60mph tuned right without blowing up.
Come on B&L... Blowing up Kymco 2t's is where all the fun is.
Besides... If I didn't have to turn around, and pick up pieces of scoot off the road, I would have no reason to turn around at all.
I would simply scoot until (god forbid) I wound up in Portland!
Blowing up bikes is a good thing.
Oh I'm with you man, blowing up 2t bikes is half the fun. Bit i get the sense a lot of people ask about performance stuff on this forum expecting a transformed bike that'll last ten years without doing anything to it. Not to mention i wound hardly recommend kitting unless you have a decent idea about tuning etc, otherwise it'll run like sh** or you'll pay someone hundreds for it to still run poorly. The only way you can get it perfect is to tune it yourself.
