Author Topic: throttle turn amount  (Read 1062 times)
Triesandluth
« on: December 03, 2014, 06:42:59 AM »
Just curious,  how much turn do you get from your throttle?  I barely have anything between nothing and wide open.  The adjuster at the bars is set to have little to no play. Is there a way to adjust it at the carb? Or is that just how it sits,  ready for action?
Re: throttle turn amount
« Reply #1 on: December 03, 2014, 06:59:47 AM »
  I think I have about 30 degrees of throttle on my 300i downtown,. on the clock that would be from 12  oclock to 2:30  oclock,.
« Reply #2 on: December 03, 2014, 08:19:20 AM »
There is an adjuster at the carb end due to the splitter that runs to the oil pump. Pull back the rubber boot at the cables end over the carb.
30 degrees sounds about right...
Triesandluth
« Reply #3 on: December 03, 2014, 08:49:35 AM »
Yeah,  I've got that. About thirty degrees. I'm still stuck on comparing my kymco to my Taotao crapper, haha.  The questioning of it did inspire me to remove the cable from the slide at the carb,  which revealed a nice amount of grit and grime.
« Reply #4 on: December 03, 2014, 11:11:59 AM »
I like your Sig.    ;D
Triesandluth
« Reply #5 on: December 03, 2014, 10:17:42 PM »
Thanks! It's a daily battle.  Not as much today.
« Reply #6 on: December 03, 2014, 10:49:22 PM »
Much like mine...
 I had ONE person that the ??? had an influence over... Guess what? We're all people.
