Author Topic: LIKE200i Torque Specs  (Read 2559 times)
« on: December 06, 2014, 02:41:22 PM »
Here you go Robo,
Courtesy of Cyclepedia
Stig (37, rain, wind ----"Meteo scooter di merda !"){per bing translator - hope this is not rude!}
vespbretta
Re: LIKE200i Torque Specs
« Reply #1 on: December 07, 2014, 07:03:20 PM »
Thanks Stig. Thats for sure helpful for many self made mechanics who are not used to work with aluminium parts.
Cheers,
Robo
vespbretta
« Reply #2 on: March 25, 2015, 09:37:51 PM »
The Drive Face Nut Torque Value of 93.1 NM /68.7 ft-lb from Cyclepedia might be be (way) too high...
Talked to a Kymco mechanic today and he said probaly 50NM, Maximum 60NM would be fine.
Personally I wouldn´t want to go above 70NM either.
Just as a comparison:
The Kymco Like 50/125 Torque Values allegedly are
Drive face nut       NH12 5.0 - 6.0 kg-m  or  50 - 60 NM
Clutch Outer Nut  NH10 3.5 - 4.0 kg-m  or  35 - 40 NM
The Kymko Dink 200i/125 Torque Values allegedly are
12mm bolt and nut 5.0 - 6.0 kg-m  or  50 - 60 NM
14mm bolt and nut         7.0 kg-m  or  70 NM
I´m still unsafe here, but maybe B&L can and will bring light into darkness.  ;)
Nobody wants to come this nut loose of course  :o, but too tight might cause other problems (crankshaft thread, bearing pressure crankshaft, etc.).  :-\
« Last Edit: March 25, 2015, 09:39:50 PM by vespbretta »
Cheers,
Robo
« Reply #3 on: March 26, 2015, 09:08:52 PM »
Hello Robo,
I somewhat agree......when installing sliders and a new belt, and de-glazing my clutch pads ....I have a new torque wrench - but felt the figures were too - something for my taste.
So, I just gave it a nice snug tightening with the T. wrench while staring at the size of that nut and shaft and using 40+ years VW-wrenching experience. I did use new nuts - cheap insurance.
kjems
« Reply #4 on: July 06, 2022, 02:29:14 PM »
Saw this and wondered about the rear axel nut. Manual say 120 Nm
Thats ok? and here also correct to use loctite?
Kindly Jesper
« Reply #5 on: July 06, 2022, 07:08:56 PM »
Yes, this values seem to be a little bit high.
See attached schedule for torques on our Kymcos in general.
120 NM is fine for this axle, can't overdo.
Little bit blocker cannot harm, but not really necesserary.
