I have a 2011 DT. 53,000 km. the belt # is OK. should be made by mitsuboshi, good for 20,000 km. if you can check the width of your belt it could be 25.2 mm. x 1004 mm. with a 30 degree pitch ,. I have ordered 3 belts so far and they are 24 mm. wide, you may have got a wide one by chance,. that will give you lower RPM in all speeds,. but the top speed is the same, I got mine up to 150 kph at 7,500 rpm. but I can cruise at 120 kph. at 6,000 rpm. , with a modded variator extend the slope for the sliders 1/4 ",. and I use dr. pulley sliders 20/12 15 grams. if you want more go use 14 grams,. got 20,000 km. on the sliders and they look like new., enjoy your scooter as much as I DO ,. ride safe
