Author Topic: Pre mix fuel ratio  (Read 2327 times)
Berzerker1965
Pre mix fuel ratio
« on: December 15, 2014, 04:11:47 PM »
What is the ratio for pre-mixing fuel? Ounces oil per gallon of gas.
2013 Like 2t
Derestricted bushing
So far...
Live for today for tomorrow we may die.
Re: Pre mix fuel ratio
« Reply #1 on: December 15, 2014, 10:36:18 PM »
It depends on the oil.
Most are 50:1 ratios so... 2.5 ounce of oil to 128 oz. (gallon)
Some are 32:1                 4 oz to a gallon
Your bike runs OEM between 100, and 50 to one depending on throttle position from the factory but you can use any QUALITY oil at the ratio the oil manufacturer suggests.
Don't cheap out. Buy GOOD oil. I use...  http://www.spectro-oils.com/platinum-sx-321/
Berzerker1965
« Reply #2 on: December 16, 2014, 04:01:49 PM »
Thanks you, guys are awesome.
2013 Like 2t
So far...
« Reply #3 on: December 16, 2014, 10:05:54 PM »
Not as awesome as you Berzerker...
ParaIndiana
« Reply #4 on: March 22, 2015, 08:15:51 PM »
I've run about a 50:1 ratio for a long time now. Seems to be working good so far. It's a little smokey on start-up, but once it's up to temp it's just fine.
2011 Kymco Like 50 2t
Malossi 70 BBK
Malossi 19MM Carb
Stage 6 Sport Pro Clutch
Pod air filter
Malossi CF Reeds
Polini torque spring: Blue
Naraku Sport Variator
Naraku Sport Torque Driver
Naraku Half Pulley
5.5G Dr. Pully Sliders
Stage 6 +15% Primary Gear Kit
Malossi Belt
Pre-mix Fuel  45:1
