Author Topic: question about variator nut removal  (Read 7783 times)
boo
« on: December 27, 2014, 08:54:28 PM »
The shop where I bought my GT overtightened, and or used Loctite on my variator nut. They replaced a leaking oil seal under warranty.
Some time back I tried to loosen it so I could try some Dr Pulley sliders.
Long story short, I could not get the nut loose.
Have since picked up a two foot long cheater bar to use over my power bar.
Here is my question: Will it hurt anything if I use a propane torch to heat the nut and hopefully break the seal to remove the variator nut?.
I suspect they used Red Loctite.
Have about 8,800 miles now and plan to replace air filter, drive belt, new variator nut, and install Dr Pulley sliders at 12,000 miles.
« Last Edit: December 27, 2014, 08:59:51 PM by boo »
300GTI black
Pro 2A - member GOA & NRA
Re: question about variator nut removal
« Reply #1 on: December 27, 2014, 10:34:39 PM »
The torch will be fine IF you heat it just past hand hot. You only want to melt the compound, and avoid softening the crank end.
I would do it but I would also hold out for an impact driver. I swore we didn't need them but I have long since changed my mind.
Worse comes to worse... A new crank, and gasket set is under 50 bucks on Ebay.
« Reply #2 on: December 27, 2014, 11:20:35 PM »
+2 on the impact gun. It's the way MEN take apart the variator. You can get a cheap harbor freight electric. I spent $300 on a SnapOn about 8 years ago and it's still going strong.
boo
I used
« Reply #3 on: December 27, 2014, 11:52:59 PM »
an electric and air impact wrench and nut would not budge.
It is a tight son of a bitch.
Guess I will try heat first. If that doesn't work i'll cut it off with a Dremel tool.
Really, really do not want to damage my crank threads.
300GTI black
« Reply #4 on: December 28, 2014, 12:08:10 AM »
Lefty loosey.righty tighty.
« Reply #5 on: December 28, 2014, 01:15:01 AM »
Take it back to the shop and tell them they messed it up, better to do this than F*** up your crank. Let them do that lol.
« Reply #6 on: December 28, 2014, 04:26:37 AM »
I'm surprised an impact that could not budge the nut, didn't shear off the threaded end of the crank.
Maybe B&L is right in suggesting you run it by that shop. It's a coin flip now as to weather the not will come off with/without the end of the crank.
If that coin lands on edge, everything will be fine. 99.999:1 shot.
If it is red LokTite tho, the heat will melt it well below 300* f. edit that... I just found this...
"Here it is from the horses mouth. The Loctite corp..
Q: How can I remove a fastener that is "permanently" locked in?
A: The application of heat is needed to remove a fastener that can't be removed with a hand tool. Temperatures of 325F and above is needed to break down a standard anaerobic, 500F for high temperature Anaerobics. A heat gun or propane torch is commonly used to do this process, and careful disassembly should occur while parts are still hot. Once apart, and cooled, use methylene chloride (Chisel #79040) to remove cured excess material. Always wipe down the fasteners with clean up solvent to remove the wax film that Chisel leaves on the surface."
« Reply #7 on: December 28, 2014, 06:01:51 AM »
This may be a dumb question, but you are trying to take it off counter clockwise right? Just checking..... I've never had a nut with red loc tite be That Hard to get off .
« Reply #8 on: December 28, 2014, 09:02:53 AM »
Dude... It'll snap a 1/2" bolt w/ no problem. I've used it on crank bearing caps for decades, and it always requires heat to get the nuts off.
That crank shaft end is just 2mm over 1/2"
boo
« Reply #9 on: December 28, 2014, 02:50:12 PM »
Yes, counter clockwise.
I was a mechanical trouble shooter/line tech in a factory for years. I have never seen a small nut this tight. The shop must have added Red Loctite and held an impact wrench on it for five minutes.
When I get the old nut off, I think I will use Blue Loctite and proper torque on the new nut.
Don't want to go through this again.
300GTI black
« Reply #10 on: December 28, 2014, 10:29:29 PM »
Fingers crossed!!!
« Reply #11 on: December 28, 2014, 11:25:14 PM »
Yep, fingers crossed...my like had a factory crazy tight nut when I put Dr Pulley sliders in.....actually find factory tightened fastenwrs crazy tight on my Kymco and HONDA.
Agree with using new nuts.....very cheap insurance! Always use new ones.
« Last Edit: December 30, 2014, 07:46:04 PM by Stig »
Ian7
« Reply #12 on: January 04, 2015, 04:27:47 PM »
Just tried to pull the variator nut off my super8 (only 65 miles on the clock), 250 ft-lb impact wouldn't do it without a torch on the nut first....
...and three seconds with the torch virtually destroyed the adjacent plastic air vane.... where do I get a new one of those? LOL
« Reply #13 on: January 04, 2015, 10:43:10 PM »
YTou can buy one from B&L ( i think) or from Kymco Parts Monster . Com
OR just toss it. I ride lots of bikes where it has been trashed long ago.
« Reply #14 on: January 04, 2015, 11:43:50 PM »
What are you referring to? I can't picture what it would be. The fan on the variator?
