Hmm. I run the stock pipe, fully clipped, with a few holes (not suggested, mine came with them) and just went up to a 95 jet. I may need to go higher. I'm running 9 gram rollers, top speed average 42mph gps, past the 80 kmh on the speedo. That's at about 7500 rpm. What rpm did you're stock pipe hit?
Just a thought, does the pipe hold pressure? If it's cold, started, and hold your hand over the outlet it should die, or try to, and let out a pressure when you remove your hand.
Don't attempt it hot, even with a towel. My dumb a** almost caught fire thinking the towel was resistant enough...
