Author Topic: exhaust outlet gasket?  (Read 700 times)
chaz35
  • old guy
« on: January 01, 2015, 08:13:21 PM »
People 50 has OEM exhaust and round exhaust outlet gasket.  Super 9 LC with Tecnigas pipe has flat exhaust outlet gasket.  I guess dumb ?, but are these gaskets interchangeable?  The round gasket looks like the better design to me.
Re: exhaust outlet gasket?
« Reply #1 on: January 01, 2015, 11:49:59 PM »
You can use one or the other. The flat diamond shaped can be reused but the doughnut ones are compression fit and one time use.
chaz35
  • old guy
« Reply #2 on: January 02, 2015, 03:55:17 PM »
Thanks for reply.  Makes sense to me, but was surprised donut is one time use.  Weather is cold and wet here, hope better for you.  Cheers
« Reply #3 on: January 02, 2015, 04:37:10 PM »
Some bikes you can get away with reusing them, my 250 leaks a little if I don't use a new gasket. Is like 20oF here, no rain but a cold ride into work today haha.
