Have to pump the brake lever, I didn't make that clear. Open the bleeder valve at the caliper, pull the brake lever and some brake fluid will come out, close the bleeder valve, then release the brake lever, repeat many times. Watch the brake fluid level at the master-cylinder and add as needed. After the air is out of the system, the brakes will be nice and firm. Cheers
