Finally got Tecnigas Next-R pipe installed. I originally tried to order 1-1-15, took 2 weeks to figure out they didn't accept my credit card payment, so ordered again. Long story short, took long time for parts to come in. By the time I got the parts, wasn't sure I still wanted to mess with my 50's anymore. Been looking at Sym HD200, Honda PCX150, People S 200, etc. Finally got over bigger scooters, still like my 50's the best.
For test, I just installed the pipe, added pod air filter, and rejetted the carb. People 50 2T is AC so I wanted to be sure jetted rich, because seems like I run it WOT 90% of the time. I installed the largest jets I had: 45 idle jet, and 108 main jet. Fired it up and took for test run approx 1 hour, maybe 40 miles. I wasn't planning to run it that long, but was so much fun, I just kept going and going.
Runs good, top end definitely better, mid range a little better, low end not as good as before, but that was expected. Actually, wasn't bad low end, seemed to run a little better longer I ran it, maybe blew out the pipe a little. Pipe was a lot quieter than old Tecnigas pipe on Super 9, so new muffler makes a big difference.
For CVT, as recommended by Z, I have Malossi 5.1 gr rollers, and Malossi purple torque spring. I pulled off the CVT cover, and took off the variator and clutch. Everything looked good and appeared to be OEM. I checked the width of the belt and seemed a little less than new belt, but appeared OK. I measured and came to approx 17mm, so I didn't replace it. I replaced the rollers with new Malossi 5.1 gr rollers and put it all back together. I want to test it again, before I change out the torque spring. The torque spring looked red, so maybe that was aftermarket, I don't know.
I used my impact driver to disassemble and reassemble with blue loctite . I would rather use a torque wrench, but haven't firgured out how to hold variator/ clutch, plus seems everybody else just slams it on with impact drivers now a days.
Supposed to rain next few days, so will test and report back when I can. I didn't test tonight, want to let loctite set.
I really like my People 50 2T, maybe as well as Super 9 LC. Super 9's are pretty rare around here, but People 50's come up from time to time, will probably get another one. Cheers
