White torque spring too stiff, revs way past powerband, no top end speed. So, kit as it came with 9gr rollers, white torque spring doesn't work for me. Maybe would work on more modified engine with more HP and higher powerband, I don't know. Actually, after doing a little research, I think it may be for an over range rear pulley, which is not what I have, but maybe some that buy the kit have an over range rear pulley? Apparently, just the color is not all you need to know, not all Malossi white springs are the same.
Put it back the way it was with new Malossi variator, Kymco OEM torque spring and Dr Pulley 7.5gr sliders. Ran pretty well, really likes to stay in low gear and rev, pretty much have to give it WOT to get going, took awhile to get use to. Once moving, works a lot better keeping revs up if get slowed and need to accelerate again, revs will come right back up. Top end a little better, I really like the mid and top end with the Malossi variator. Seems like it needs a little heavier rollers, so will try my OEM Kymco 8gr rollers next. I like it, don't want to go back to OEM variator at this point. Not sure, but seems faster in traffic.
Pretty confused about Malossi torque springs. I thought the white spring was supposed to be OEM replacement. If you look at a torque spring with the end on top and bottom facing you and count the wires, I get 8 for the white, 6 for the purple I have, 6 for the OEM Kymco. If you search for images on the web you can count number of coils for the same colors and get different numbers. Seems like 7 is the correct number of coils for standard rear pulleys and maybe more for over range pulleys, I don't know. Anyway, the white one I got with the kit I can't use. Now I know why the purple one works so well, it's not +82%, is missing 1 coil, has 6 appears should have 7, so is probably same as OEM Kymco. Torque springs, something else to learn about. Cheers
