Author Topic: Plowing...  (Read 4442 times)
Re: Plowing...
« Reply #15 on: February 06, 2015, 04:52:37 AM »
The Fairlead?
Molon Labe
Re: Plowing...
« Reply #16 on: February 06, 2015, 06:58:15 AM »
The Fairlead?
No, it's not part of the winch it's part of the plow setup.
The winch cable connects/loops (or goes through/under) to the plow via a small wheel device.  That small wheel can be removed and attached to the plow mount via a pin.
The wheel rotates as the cable is let in/out to control the height of the plow blade.   It works as a pulley system basically.  I'll get a picture of it.
Molon Labe
Re: Plowing...
« Reply #17 on: February 06, 2015, 07:06:19 AM »
This is sort of what I'm talking about, although mine is slightly different.
Re: Plowing...
« Reply #18 on: February 06, 2015, 09:00:37 AM »
Cool...
This is listed as the "plow cable guide... It will direct replace yours
http://www.amazon.com/Warn-81271-Plow-Rope-Guide/dp/B0041CC93O
This is listed as the "upgrade kit, and needs to be retro fitted...
https://www.warn.com/atv/plows/plow_pulley.shtml
I guess I found what you did.
Try Granger for the pulley you have now. That would be my guess.
Never mind... I found one for ya!
http://www.mscdirect.com/product/details/67326686
I think what you have is an oddball. Like an in between rig.
Is your plow a Proadvantage? or the entry level version?
Either way the one I found will work.
