Author Topic: 2 Crankshafts for the Agility50 and 125  (Read 715 times)
nightriderrv
  • Ride all the time !!!!
« on: January 09, 2015, 04:45:19 PM »
I have 2 cranks that I changed out of a 50cc KG10SA and a 125cc KN25SA
The 50cc locked up the wrist pin but the bearings are fine the shaft came out of a running engine which loss oil due to a seal leak, the owner tried to get the flywheel off and a hammer but could possible be saved.
The 125cc was running the bearing was making a lot of noise that shaft seems fine if someone has a bad shaft and some good bearings the side where the bad bearings was at I cut the outer part of the bearing off to see the numbers and the small part that's left can be turned by hand so there is some ware in that spot.
If anyone is in need of them send me a pm or email
« Last Edit: January 10, 2015, 12:38:32 AM by nightriderrv »
2007 Agility 50 4T KG10SA
52MM Hoca BBK
Big valve head
24mm Keihin
102.5 jet
UNI filter
Aftermarket exhaust
Malossi Multivar
6g Malossi rollers
Stock clutch & white Malossi contra spring
Primary transmission gear up 18/50
Re: 2 Crankshafts for the Agility50 and 125
« Reply #1 on: January 09, 2015, 11:54:51 PM »
Nice offer... I have a shed full of project cranks or I would have jumped.
nightriderrv
« Reply #2 on: January 10, 2015, 12:36:25 AM »
Thanks I was thinking if someone needed them or something off of them just pay the shipping, those Kymco cranks are not cheap  :( :(
52MM Hoca BBK
Big valve head
24mm Keihin
102.5 jet
UNI filter
Aftermarket exhaust
Malossi Multivar
6g Malossi rollers
