Author Topic: no spark.  (Read 8941 times)
gremlim
no spark.
« on: January 10, 2015, 07:22:01 PM »
Hi all
I have been trying to find the cause of my 2t not starting. I have changed the cdibox and the plug and iignition coil but still no spark. Does anyone know what ac volts I should read on a multimeter when kicking the engine overIhaveacread lots of different things and the ffigures vary from .5ac to 80 ac
Re: no spark.
« Reply #1 on: January 10, 2015, 09:14:05 PM »
Is the "stop/run" switch in the "run" position?
gremlim
Re: no spark.
« Reply #2 on: January 11, 2015, 09:12:24 AM »
It doesnt have
 one
Re: no spark.
« Reply #3 on: January 11, 2015, 07:51:00 PM »
These might help... Also does your scoot have a kill switch on the side stand? Many do!
One other thing... You're bike fires DC input for the CDI, meaning the rectifier has to be working to supply DC voltage.
If you read ANY ac voltage by spinning the flywheel I would suspect the rectifier went bad or the connector to it failed.
gremlim
Re: no spark.
« Reply #4 on: January 11, 2015, 08:57:26 PM »
The side stand has no switch. I have checked the  rec as per the manual but dont get the same readings. Also thebike got harder and harder to start and the low beam headlights stopped working as well. Would that be the reg/rec as well?
 I thought the cdi was ac as the service manual says that Its  a uk 50cc 2sttroke ifthat makes any difference.
« Last Edit: January 11, 2015, 09:03:49 PM by gremlim »
Re: no spark.
« Reply #5 on: January 11, 2015, 09:24:51 PM »
Ok, back to the drawing board. I assumed it was a 4t 50...
The head light is also AC fired so if it is not coming on when you kick the bike, your stator has failed. Since the rectifier is under 20 bucks I would also replace that if the readings are off.
Stators can spike voltage, when they fail, and take everything else out w/ them. Get OEM Kymco parts cause matching other China parts is a pain.
gremlim
Re: no spark.
« Reply #6 on: January 11, 2015, 10:12:38 PM »
Thanksfor the help I will get one asap  :)
MrBoston
Re: no spark.
« Reply #7 on: January 12, 2015, 04:10:19 AM »
You might not be getting any spark due to a defective spark plug or ignition coil. The ignition coil is the part that sends the spark.
gremlim
Re: no spark.
« Reply #8 on: January 12, 2015, 06:36:34 PM »
I have tried new ignition coils so I think zombie may be right. The lightss don't come on when I kick it over
gremlim
Re: no spark.
« Reply #9 on: January 24, 2015, 08:05:31 PM »
An update on this problem. I have tried a new stator and still have no spark. Would the reg/rec have any influence on this?
gremlim
Re: no spark.
« Reply #10 on: January 26, 2015, 04:42:01 PM »
Anyone have any ideas? :)
Re: no spark.
« Reply #11 on: January 28, 2015, 12:52:01 AM »
Try un-plugging the rectifier, and see if you get spark. It may be shorting the stator to ground.
Also try clipping the black, and yellow striped wire to the CDI. That is the kill wire.
gremlim
Re: no spark.
« Reply #12 on: February 14, 2015, 09:00:25 PM »
I have checked all the wiring and cannot find any breaks. Does the reg/rec have any influence on the spark? As thats the only part I havent changed.
Re: no spark.
« Reply #13 on: February 14, 2015, 11:47:43 PM »
Yes because it is a DC fired CDI. That means if the rectifier is shot... No spark
gremlim
Re: no spark.
« Reply #14 on: February 15, 2015, 08:36:02 AM »
I am now a bit confused when I got the bike the battery was flat but the bike still ran. I figured that means its ac fired am I wrong :-)
