Did you miss your
activation email
Scooters - 125 to 300
Super 8 150
New super 8 150 motors
Pages:
Topic: New super 8 150 motors (Read 6392 times)
Carter Merz
Re: New super 8 150 motors
Reply #15 on:
February 01, 2015, 01:28:18 AM »
If the con rod broke, the crank shaft is done. It's not very expensive to get a crank, poison, cylinder, and head. Cheaper than buying a wrecked bike.
You never know do ya!
Close enough to get the idea!
Reply #16 on:
February 01, 2015, 02:48:00 AM »
Just thought... Timing chain too. Still about 100.00 less than a new engine. But. New is new.
Metreaus
Newbie
Reply #17 on:
March 02, 2015, 06:56:21 AM »
Swapping a standard GY6 engine may work, but you must be ready to do a stator/flywheel swap.
I was the person who tried to do the GY6 swap in an Agility 125. The issue I also had with the swap was
rear tire clearance.
The design of Kymco's rear wheel may have the rear tire rubbing the engine case. So you might have to settle for a different wheel from a standard GY6 scooter so it fits on the axle properly without rubbing the case (after installation of the rear wheel bracket).
It's possible to do if you're willing to make a few sacrifices.
Back
