Author Topic: Get More powerful battery for the X-500  (Read 893 times)
« on: January 24, 2015, 03:25:16 PM »
From a recent question regarding a bigger battery to possibly cure an issue with these big scoots...
I don't know how hard it is to measure the battery box on your big scooter, or to see what you have in there for a battery.
I took out my battery, measured it, measured the space it fits in - then went to this YUASA site to see what my battery specs were - and what I could up-grade to that would still fit the space in my scooter. Found this more powerful one that fit with just a quick trim to the battery hold-down pins on the battery cover.
http://www.kymcoforum.com/index.php?topic=11456.msg114986#msg114986
The YUASA site is where I found the better/bigger battery - with the same mounting type for the posts, etc., etc.
 There was nothing listed for my scooter - I just used the info from my OEM Yuasa battery and searched out same sized one with more grunt. Back and forth to my scoot to make certain the new battery would fit - then ordered it from Amazon. Do some reading there and hopefully you can find a more powerful battery that will work in your scooter.
Regards, Stig (I noted that the same big battery I put in my little LIKE is the same battery that came in my bigger Honda Forza)
 YUASA specs and charts .... http://www.yuasabatteries.com/pdfs/Yuasa_Specs_Apps_2014.pdf
bongoman
Re: Get More powerful battery for the X-500
« Reply #1 on: February 04, 2015, 04:57:19 PM »
I recently switched to a lithium battery from my LMS. A little stronger than OEM. More expensive at first, which is actually cheaper in the long run because battery comes with a 5 year warranty instead of 1 year. Also keeps charge longer in slow winter months. Have not used a bettery tender yet, and no issues even after sitting about 2 weeks. When it's cold, you have to wait as long as 5 minutes after turning the key on to "warm up" the battery. It's like the battery hibernates or something.
2009 Xciting 500
2015 Lance Cali Classic 150
