Author Topic: Kymco Super 8 50cc 2t derestrict  (Read 5138 times)
JRowse
« on: January 28, 2015, 07:30:37 PM »
Hey guys, Could someone help tell me how to de-restrict the CDI on a super 8 2012 model.
Re: Kymco Super 8 50cc 2t derestrict
« Reply #1 on: January 28, 2015, 10:24:23 PM »
Hey JRose, Welcome.
Wait for someone to verify this but I think it is a pink wire that gets cut on your CDI. Too many shots to the head so I forget a little.
Not to be a smart ass but while your waiting try searching S 8 derestrict here. It migh give you the answer.
« Reply #2 on: January 29, 2015, 02:44:12 AM »
Rev your bike on the center stand, does it hit a rev limiter? If not then it's de restricted already.
« Reply #3 on: January 29, 2015, 02:47:44 AM »
Hitting the rev limiter...
« Reply #4 on: January 29, 2015, 02:57:05 AM »
Brappp
« Reply #5 on: January 29, 2015, 03:02:02 AM »
That kids funny.  ;D ;D ;D
JRowse
« Reply #6 on: January 31, 2015, 04:04:23 PM »
Yes it hits a rev limit. Also it does not have a pink wire that is the old model i believe. When it hits 35 mph it can not push any harder as it sounds like it is about to blow up. I have a kit, pipe, carb, i have clutches which are not on yet but will help but i know that there is a restrictor in the cdi i just do not know how to remove it.
« Reply #7 on: January 31, 2015, 06:36:13 PM »
I found an old thread here that might help. It a 2t people but the same as yours.
Do you have the green wire w/ a connector?
http://www.kymcoforum.com/index.php?topic=2150.0
« Reply #8 on: January 31, 2015, 06:58:55 PM »
The super 8 isn't that easy! Also on the newer than 2007 people they took that easy derestriction wire off! Those dicks
« Reply #9 on: January 31, 2015, 07:03:57 PM »
Then I wonder if the s9 adapter module, and CDI would work?
Racing Planet has them for under 70 bucks I think
Pimpy1
  • Mo Hoes Power
« Reply #10 on: February 12, 2015, 10:01:38 PM »
The Super 8 2t 2012 CDI is not restricted and replacing it will not make your scoot faster.
2011 Kymco Super 8 2t
2006 Kymco People 250
