Author Topic: When starting the scooter, it putt putts then dies... what does that mean?  (Read 2953 times)
spikebites
This has happened to me twice now.  When I start the bike, it ignites, then sputters a little then dies.  Then I have to start it again.
If I manage to add a little throttle to it before it dies, it will be fine.  It's not a huge problem, I'm just curious what the issue might be.  This happened on a full tank of gas, so it's not a gas issue.
I would adjust the Idle Mix screw before anything else. See if that helps.
Possibly carb clean also, had the bike ever sat for more than a month?
windwheeler
    • WindStrom windshields
Guys, wake up, he is asking about a Downtown300i with fuel injection!  ;)
Spikebites,
-- how many miles on your D/T?
-- For how many miles did YOU have it?
-- Is that something that just happened, or  got worse over time?
-- What is the ambient temperature when this happens?
-- Cold and warm start the same or different?
Spikebites,
Just saw that lol. It could need the tps reset
  do you fill with gas and park ,on a hot day it will have gas over flow and will cause hard starting,. I allways fill my scooter before going on a ride,  parked empty,.    2011 300i DT.  60,000 km. runs better every year,
I hate Kymco's >:(
souzamoto
Sounds like you overfilled the tank flooding the evap can. Now it pulling extra fuel, rich at start up and basically wants to act flooded...maybe.
CS
I would go for the TPS reset also called "Initialize". I'm not gonna say a word about idle mix adjust or carb clean....not a word.
No need!
spikebites
I'm not sure if any of these suggestions worked, but my problem seem to have corrected itself.
