Did you miss your
activation email
Scooters - 50cc
Gas in crankcase oil
Topic: Gas in crankcase oil (Read 1086 times)
scooterman11
Jr. Member
January 29, 2015, 07:04:57 PM »
I keep getting gas in the oil of my 2008 kymco agility 50
What is causing this?
Carter Merz
Re: Gas in crankcase oil
January 29, 2015, 09:08:18 PM »
Bad fuel petcock and bad carb float needle. Both are under $50.
You never know do ya!
Close enough to get the idea!
January 29, 2015, 10:24:20 PM »
Ebay 20mm carb 25 bucks, and a petcock from Parts for scooters 10 bucks.
Keep the old carb for parts.
Reply #3 on:
February 02, 2015, 09:37:23 PM »
X 2 just drane the bad oil put in fresh.new carb and pedcock and your good to go.
240karl
Newbie
Reply #4 on:
May 30, 2015, 05:17:28 PM »
Just found this I've got the same problem on my agility, thanks
scooterdad2324
Full Member
Reply #5 on:
July 03, 2015, 07:40:58 PM »
Same here hopefully I can get it fixed soon
Sent from my XT1526 using Tapatalk
Back
