Author Topic: Electrical Fault? Shuts off after short drive and that's IF it ever turns over  (Read 565 times)
PiratePi
So I've had a service done and everything checks out but the mechanic suggests an electrical fault. Have replaced the CDI and Coil with no luck. Also installed brand new battery.
What happens is it just won't turn over and whenever it does, the engine shuts off after a half kilometre drive and then struggles to start up again. There's a long deep squeak when I continue to attempt a turn-over.
Any ideas?
tortoise
Any ideas?
Test cold and warm engine pulser coil Ohms.
Will the engine not kick-start?  Have you verified spark?
