Author Topic: 12 VOLT OUTLET  (Read 1874 times)
glaswurks
12 VOLT OUTLET
« on: February 19, 2015, 11:07:24 PM »
HI ALL,
DO YOU SUPPOSE THE 12 VOLT OUTLET PLUG ON MY DT300 WOULD BE SUFFICIENT TO OPERATE A TIRE INFLATOR?
windwheeler
    • WindStrom windshields
Re: 12 VOLT OUTLET
« Reply #1 on: February 19, 2015, 11:20:51 PM »
Nope, anything else than a cell phone will blow the only 0.8A fuse, that is hidden behind the front fairing.... cumbersome to get to if it is blown. You could unofficially go up to a 3A fuse, but this still is not enough for your tire inflator.
glaswurks
Re: 12 VOLT OUTLET
« Reply #2 on: February 19, 2015, 11:27:17 PM »
ONCE AGAIN, THANKS FOR YOUR EXPERTISE
mrmike
  • Syuracuse, NY
Re: 12 VOLT OUTLET
« Reply #3 on: February 19, 2015, 11:40:00 PM »
I had the same thing with my GTI. The factory outlet (under the seat) is only fused for a cell phone charger. I bought a marine grade accessory plug and wired it direct to the battery with a 10amp in-line fuse. I use it for my GPS and my battery tender when the scoot is up for the winter. Pretty simple DIY project. Hardest part is finding a mounting point for the plug.
bluesin
  • 2012 DT 300i
Re: 12 VOLT OUTLET
« Reply #4 on: February 20, 2015, 01:59:55 AM »
Upgraded mine to 3A just to make sure it doesn't blow with GPS .
Re: 12 VOLT OUTLET
« Reply #5 on: February 20, 2015, 04:57:00 AM »
  I opened the front end and rewired with # 10 wire and installed a  panel fuse beside the plug in so I can fuse it to any amp. thing I want,  pictures in downtown section from don jack from  scotland,
bluesin
  • 2012 DT 300i
Re: 12 VOLT OUTLET
« Reply #6 on: February 20, 2015, 01:39:37 PM »
Have to check that out !
