Did you miss your
activation email
Technical | How To
Agility 50 oil leak
Topic: Agility 50 oil leak (Read 1613 times)
juniorbear5531
Newbie
Agility 50 oil leak
November 05, 2009, 07:23:21 PM »
ok, got oil leaking around gasket on bottom. there is some play in the gasket, but the dealer says he tightened the gasket and it all looks good. I'm seeing two or three quarter size drips on ground after it sits for a few hours,,, any ideas?
You never know do ya!
Close enough to get the idea!
Re: Agility 50 oil leak
November 05, 2009, 08:17:07 PM »
Which gasket are you referring to, and what do you mean by "play". the easiest way to find a leak is to thoroughly clean the suspect area. I use Brake Clean. It dries almost imed.a and its pretty cheap. Clean thing up to see exactly what is leaking, and take it from there
undead primate
November 05, 2009, 09:06:48 PM »
..if you're talking about the cvt cover...the only place that i'm familiar with there being a gasket...then you should remove the cover to locate from wherest the oil comes...could be a failed drive shaft seal..could be a failed crankshaft seal....
..the gasket can be held in place wth a thin film of adhesive..it's a pain to keep in place whilest playing around in the cvt..
peace
Last Edit: November 05, 2009, 09:09:07 PM by wordslinger
tp376
Newbie
Reply #3 on:
December 31, 2009, 07:28:57 PM »
Hello Tommy here from TNT Cycles. I am the technician and if you could use the obline parts diagram at
www.tntcycles-atv.com
to point out the cover, I could better answer your questions. Thanks.
Certified Kymco Tech willing to give Free help.
Back
