Author Topic: My Kymco side by side has lost power  (Read 1487 times)
schambermerv
« on: February 21, 2015, 09:04:45 PM »
r.p.m. only goes to 4500  changed oil plug runs fine but no speed or power,  can only get to 4500rpm in neutral  Can someone help please
Re: My Kymco side by side has lost power
« Reply #1 on: February 21, 2015, 09:40:48 PM »
Did it sit for awhile? Check the spark plug? Compression test? air filter? fuel filter? exhaust bearings?
Welcome to the forum!!!
Fill us in a little bit more. What have you done to trouble shoot? Did this happen while riding? fell off a mountain?
 ;D ;D ;D
schambermerv
« Reply #2 on: February 21, 2015, 11:20:42 PM »
nope, use it everyday to feed horses, just changed oil and new plug and cleaned air filter,  No change  Thanks for the welcome :D
« Reply #3 on: February 22, 2015, 02:41:06 AM »
Then I would move to the fuel system. Pull the petcock, and remove the screen up in the tank. They get clogged real easily. Then add an In=line fuel filter, and pull the carb. You need a can of spray carb / brake clean. Pull it apart, and clear all the passages.
The jets / ports may be clogged.
The next thing is a compression test. Maybe a burnt or sticking valve. Maybe the valves just need an adjustment.
This should keep you busy for a minute.
Since it does run, it HAS to be somewhere in this list.
 You're welcome for the welcome. Thanks for saying thanks! ;D
schambermerv
« Reply #4 on: February 22, 2015, 08:09:48 PM »
thanks  Doesn't have a carb, fuel injected. Going to try compression test. If that isn't it think it could be the clutch.   appreciate the insight
solberglandandcattle
« Reply #5 on: February 24, 2015, 03:14:15 PM »
Can you post your findings after you do the compression test and such. I'm having the same troubles and can't figure out the problem
« Reply #6 on: March 08, 2015, 04:37:22 PM »
Hey just seeing if you ended up fixing the problem with your kymco?
Macman
« Reply #7 on: March 10, 2015, 10:49:55 PM »
 Does it feel like a limiter at 4500?  Maybe ignition coil is failing.
