Author Topic: Mini-lathe?  (Read 1232 times)
Yager200i
Mini-lathe?
« on: February 22, 2015, 05:19:11 AM »
Anyone know of a good quality mini-lathe for not too much money? I found a Grizzly 4"x6" for $350, but that's a bit high for such a tiny lathe... I'd expect to pay that much for a 7"x10" or 7"x12".
I don't want one of those cheap Chinese things that use the 12 volt motor... I hear they burn out after a few uses.
I want to be able to custom-turn my own variator weights... once I get good at doing it, I could even make them for anyone here who wanted to experiment with their variator weights... for far cheaper than buying new weights... a 12 foot section of machinable brass to lathe the weights from is only ~$63, and you can make about 12 to 14 weights per foot of round brass rod. Lathe them to the correct OD, excavate the inside to get the weight near where it's supposed to be, then use a Dremel and a gram scale accurate to hundredths of a gram to tweak the weights so they're all within 0.01 grams of each other.
It'd make it easy to try out odd-weight sliders or rollers to fine-tune the variator to exactly how you want it to perform.
Just press out the brass center of your slider or roller, freeze the new weight to reduce its diameter a bit so it presses in more easily, press in the new weight, install the slider or roller in the variator, and go for a test ride.
Re: Mini-lathe?
« Reply #1 on: February 22, 2015, 09:46:31 AM »
  when I changed the Wts in my sliders I used the Wts out of the round rollers, to adjust the Wts to the right Wt. I touched them to a belt sander, to pop the Wts out put them in hot water, they come apart easy,  I found they come apart easy when they get hot , so use a little glue to keep them safe to ride,   300i downtown          60,000 km. running with 21/ 12   14 grams   dr. pulley sliders,  modded to fit
Re: Mini-lathe?
« Reply #2 on: February 22, 2015, 04:23:19 PM »
I have an OLD sears drill press that I side mounted on the shop wall to use as a lathe.
A little creative effort, and it does everything I need it to.I mostly turn plastics, fiberglass, and aluminium but I'm sure I could turn brass as well.
Yager200i
Re: Mini-lathe?
« Reply #4 on: February 23, 2015, 05:03:15 AM »
Yeah, that's the Grizzly I was looking at. A bit pricey for just a 4" x 6", though.
2wheelfun
Re: Mini-lathe?
« Reply #5 on: February 23, 2015, 01:33:43 PM »
Search, ebay all categories, micro metal lathe and a few good used ones popup.
