Author Topic: my Kymco  (Read 31290 times)
1g0g
    • Noises Of Russia
Re: my Kymco
« Reply #120 on: August 22, 2016, 01:43:31 PM »
broke the shock, I drive on one. How to know the diameters of the bolts of the shock absorber at the bottom and at the top?
found here not an expensive replacement, but I don't know if it will fit
http://www.motodart.ru/catalog/search-parts/part/63933/
Kymco Agility City 125
Mr. Paul
Re: my Kymco
« Reply #121 on: August 22, 2016, 09:13:28 PM »
The bolt looks like a 10mm x 35mm size. Do you have a store that sells nuts and bolts and hardware? If you do they can match it for you with an identical size. Make sure you get one of the same quality. Hope you get it repaired soon. Winter is coming!
2009 Kymco People 150
1993 Honda Helix
1g0g
    • Noises Of Russia
Re: my Kymco
« Reply #122 on: August 24, 2016, 12:50:24 PM »
thank you! found in the catalog!
95801-10035-08 BOLT FLANGE 10*35 (C) BOLT FLANGE 10*35 (C)
95801-08032-08 BOLT FLANGE 8*32 BOLT FLANGE 8*32 2
boltbrainz
Re: my Kymco
« Reply #123 on: August 24, 2016, 03:19:22 PM »
greetings!
I just bought my first scooter and it's a yellow '10 agility 125. Was cheap as chips as some donkey had reversed into it and bent the (yoke, I hope?) so that the belly pan and front mudguard had to be removed to ride it. Rode it 90% of the way home until it cut out, after pushing it the rest of the way and stripping it found out it was just a worn plug connector that had gotten loose. Anyway it's in bits now and I need to rebuilt it.
Got the engine and wheel on my kitchen floor, how do you remove the rear wheel ?
It's a 26mm bolt from research but how to lock the wheel so it doesn't turn without brakes connected up and without an impact wrench ?
What should I do with the bent yoke (I hope it's not the frame, doesn't look bent but will post a picture soon) ?
Cheers!
Mr. Paul
Re: my Kymco
« Reply #124 on: August 24, 2016, 08:23:27 PM »
Thats the same bolts I found in the catalog also. Where I live I can take a bolt in to the local hardware store and they can usually match it with one of the same size and quality. Hope you get it repaired.
1993 Honda Helix
1g0g
    • Noises Of Russia
Re: my Kymco
« Reply #125 on: August 28, 2016, 01:33:53 PM »
can you put it on the ground or insert the iron stick in the wheel
boltbrainz
Re: my Kymco
« Reply #126 on: August 28, 2016, 02:52:55 PM »
Cheers 1g0g, yeah I'm going to try that, big block of wood in the wheel against the case, once I find a 26mm. reckon I'll strip the engine to bits just for fun and give it a good scrub so it looks brand new. find out what kind of fixes/upgrades I need to do in the future.
1g0g
    • Noises Of Russia
Re: my Kymco
« Reply #127 on: August 31, 2016, 01:51:15 PM »
))  8)
Decided to ground the muffler. It is a very filthy condition were cleaned from rust and painted with heat-resistant spray paint. Let's see how long it lasts. At the same time decided to paint bandwagon, but it also became ugly. Now everything is in order.
here this sh** was
brushed and acid
now here's a good, really don't know how long he will be so good )
#1g0g #kymco #kymcoagilitycity
Mr. Paul
Re: my Kymco
« Reply #128 on: August 31, 2016, 08:52:14 PM »
It looks good! Did you use a wire wheel to clean the muffler?
1993 Honda Helix
1g0g
    • Noises Of Russia
Re: my Kymco
« Reply #129 on: September 01, 2016, 01:47:57 AM »
Yes, I have scrubbed
Mr. Paul
Re: my Kymco
« Reply #130 on: September 01, 2016, 07:06:02 PM »
Thanks. I will try the wire wheel next time. It would be easier!
1993 Honda Helix
1g0g
    • Noises Of Russia
Re: my Kymco
« Reply #131 on: September 29, 2016, 08:56:43 AM »
new variator, rollers and belt - drive scooter has turned into a fun, smooth running, good throttle response,
Yes, it is necessary every season to change the consumable, and the engine will work without problems!
xsel777
Re: my Kymco
« Reply #132 on: September 29, 2016, 05:35:35 PM »
Great news 1g0g. Happy scooting.
Mr. Paul
Re: my Kymco
« Reply #133 on: September 29, 2016, 05:52:09 PM »
Glad you have your scooter running well! I always look forward to your posts. Stay warm this winter my friend!
1993 Honda Helix
1g0g
    • Noises Of Russia
Re: my Kymco
« Reply #134 on: September 29, 2016, 06:39:45 PM »
thanks to my distant friends! :D
and you are good roads!
