Author Topic: Mxu150 will not take any throttle till fully warm.  (Read 1339 times)
Rpm90001
« on: March 10, 2015, 10:14:59 PM »
Hey guys, first post here for me.   I bought my son a showroom condition 2008 (I think) mxu150 with 120 miles on it.  Bought from close friend who bought it new.
I have a problem that he said it alwasy had.   I can start it fine, but it will not take any throttle till fully warmed up.  I have to let it idle for 8-10 minutes before I can give it throttle.   Fully warm its total fine.
Anyone else with this issue?  Ideas?  My garage is heated about 65 deg, I don't think I should have to let it warm up more than a minute befor riding.      Thanks for any help,
Geo
Alligato
Re: Mxu150 will not take any throttle till fully warm.
« Reply #1 on: March 11, 2015, 02:04:40 AM »
How's the plug look?
« Reply #2 on: March 11, 2015, 04:50:11 AM »
Clean the carb and you'll be golden
Rpm90001
« Reply #3 on: March 11, 2015, 08:47:53 AM »
Plug looks new, but I will replace it.  If carb was dirty, why would it run perfect warm?
Thanks,
Geo
« Reply #4 on: March 11, 2015, 03:03:43 PM »
The idle jet is plugged, once it's warm it doesn't need as much fuel and runs ok. 99.9% of the time dying when giving out throttle is plugged idle jet.
Rpm90001
« Reply #5 on: March 12, 2015, 12:12:58 AM »
Swapped out the plug, issue is 95% gone.  Slight stumble for e first 2 minutes then all is good.  Old plug looked good..  Gas is a year old, (didn't knowthat till this evening). Will drain and fill with fresh tomorrow.   Not a bad little machine.  Thanks for help!   G
