I thought 7gm sliders would be too light and said "given them a try what the heck" but they seemed to work ok with my setup and no decrease in top speed until cold weather set in for some reason.
Once it got cold 50 deg or so, the scooter lost a couple MPH.
What exact spring did you use ? What color- still using the white ? It it highly advised on here to use the purple spring.
Did you cut a slot in the idle air screw to tune the carb ? That can also play a small part in performance.
How did you block the cancer pipe? Pictures please and I think you mean blind pipe. I assume instead of a cut and weld you put something inside to block it like rounded sheet metal or a sock.
my spring was the least stiff Malossi spring, the white one, and it only decreased my top speed and acceleration. today it changed it back to the stock spring.
what does cutting a slot mean? like loosening it a bit or something else?
cant send pics right now but i rammed a screw there from the inside and put some sealing cream, but it didn't seem to block it completely.
im just wondering how would the purple spring do any better? the white one didnt help at all and it's damn more loose. some next level sh** lmao
