Did you miss your
activation email
Technical | How To
coil
Topic: coil (Read 576 times)
gremlim
Newbie
coil
March 14, 2015, 10:20:14 PM »
Hi all. Does anyone know if the ignition coil on a super 8 has to be bolted to the frame in order for it to work?
Re: coil
March 18, 2015, 12:40:11 AM »
No I have zip tied mine up and out of the way before.on my agilty 50 so I would think its the same for a supper 8.coils have a separate ground wire. it shoulden have to be grounded to the frame.
Carter Merz
Re: coil
March 18, 2015, 01:37:28 AM »
Rule of thumb for coils: One wire, needs to be grounded. Two wires, ground is supplied by wire not frame contact. Also the ones that need to be grounded have metal tabs where it comes in contact with the body.
Back
