Author Topic: Smooth Drive Boss Help  (Read 931 times)
demeter
« on: March 15, 2015, 05:51:04 AM »
Do I need to take my variator off to know for sure if I have an unrestricted drive boss? I looked and felt it in place and it looked and felt smooth. Or is the possible restricted spot hidden in the housings on the left or right side?
2010 Like 50 2T (Malossi 70cc BBK, Tecnigas Next-R, Blue Polini Torque Spring, Yellow Clutch Springs, 5.5g Sliders, Stock Carb: 95 MJ, Stock Airbox Drilled, PIAA GT-X Headlight, Kolite 5630 Running Lights, 140/70-12 Rear Tire)
Re: Smooth Drive Boss Help
« Reply #1 on: March 15, 2015, 06:29:17 AM »
You won't have to take it apart, just the cvt cover. You should be able to feel the collar right behind the fixed pulley half.
demeter
« Reply #2 on: March 16, 2015, 05:35:50 AM »
Thanks!
vespbretta
« Reply #3 on: March 16, 2015, 03:33:51 PM »
Or you might use a small mirror to look behind the fixed pulley half. I have one of those telescope mirrors similar to those which dentists use...
Cheers,
Robo
Vintage MX
« Reply #4 on: March 17, 2015, 04:04:37 AM »
Or you could just ride it and see how fast it goes. 30 or under, you still have the original restricted drive boss. 35+, you have a smooth one. Of course, that assumes an otherwise stock Like 50 on level ground.
2011 Like 200i, 2002 KTM 200 EXC and a garage full of 1970s Motocrossers and Trials Bikes.
