Author Topic: 2010 Like 50 2T Gear Oil Change  (Read 3792 times)
demeter
« on: March 16, 2015, 06:32:43 AM »
My owners manual is ripped and maybe even missing pages... The page I did find on gear oil only mentions 1 screw.
Do I change the gear oil all via that 1 screw on the middle right? And suck it out and refill with a syringe. Or do I do like I see in all the other scooter videos? The 2 screw method. A bottom drain screw and the middle right refill screw.
I found the inspection screw (middle right) but don't want to just start unscrewing screws to maybe find a drain screw...
Thanks
« Last Edit: March 16, 2015, 07:08:22 AM by demeter »
2010 Like 50 2T (Malossi 70cc BBK, Tecnigas Next-R, Blue Polini Torque Spring, Yellow Clutch Springs, 5.5g Sliders, Stock Carb: 95 MJ, Stock Airbox Drilled, PIAA GT-X Headlight, Kolite 5630 Running Lights, 140/70-12 Rear Tire)
Re: 2010 Like 50 2T Gear Oil Change
« Reply #1 on: March 16, 2015, 10:42:28 PM »
http://www.kymcousa.com/owners/onroad/LIKE50.pdf
I gotta think they have screw #1 & #2 listed backwards.
Drain at bolt #1 and refill at bolt #2....with the specified amount >> "exchange" 0.12 L
« Last Edit: March 16, 2015, 10:51:48 PM by Stig »
demeter
« Reply #2 on: March 17, 2015, 03:14:59 AM »
Awesome! Thank you Stig.
« Reply #3 on: March 17, 2015, 03:42:48 AM »
Lol never caught that Stig, they totally do have them numbers backwards!! But more than that, the "filler" bolt theoretically is the "inspection" bolt. Just a terrible explanation of how to check the gear oil!!!! Not to mention some good chinglish.
demeter
« Reply #4 on: March 17, 2015, 03:51:51 AM »
Here is mine to help prove I'm not a total idiot.. ;)
« Reply #5 on: March 17, 2015, 04:13:03 AM »
Yeah I wouldn't listen to the manual on this one. Go get a 60cc syringe from an animal feed store or some auto parts store. Drain the gear oil from the lower bolt hole, it's actually UNDER the cvt cover. Then fill from the top hole. I believe the like 50 is 120cc.
demeter
« Reply #6 on: March 17, 2015, 06:44:04 AM »
Problem solved. Gear oil changed. Thanks everyone!
My manual and Stigs were both off (for my bike anyway). The drain screw was one screw over from the manual. Inspection/refill screw was where it was supposed to be.
« Last Edit: March 17, 2015, 07:05:51 AM by demeter »
Berzerker1965
« Reply #7 on: June 05, 2015, 03:32:17 PM »
Take a look at encyclopedia.com They have an online manual. It may help you out.
2013 Like 2t
Derestricted bushing
So far...
Live for today for tomorrow we may die.
brankulo
« Reply #8 on: August 03, 2015, 12:32:35 AM »
what oil is recommended for transmission? manual only says sae#90. any more specific recommendations?
thanks
